Browse Forums General Discussion 1 Mar 26, 2018 8:53 pm Re: Pls check images - does it look like there is a leak? 2Mar 27, 2018 7:32 pm Are these marks new? Have you cleaned the tiles and seen the marks return? Have you tried leaving paper or something around base of toilet to see if there is any water accumulation at any time? Re: Pls check images - does it look like there is a leak? 3Mar 27, 2018 7:48 pm thehuntbegins it certainly looks like a leak you will need a moisture meter or Multimeter to measure (ohms) Resistance on the grout.hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Pls check images - does it look like there is a leak? 4Mar 28, 2018 9:59 am MM would be best - but I left some paper around what I thought was a leak - turned out to be a loose fitting. Once I'd tightened it properly it was good. Never done properly by plumber I guess. No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11568 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20229 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5075 |
