Wardrobe behind wall how big
I would expect a standard depth cabinetry of 60cm or more so that you can hang up your clothes with full size hangers, and a walkway of around 90cm to walk around freely, and open up your wardrobe doors (unless of course they're sliding doors, or have no doors at all).
It kinda depends how much space you have to play with though...
Old Home Restoration / Renovation
Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts
8/08/2023
3
Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the…
11/09/2023
6
Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused.
