Browse Forums General Discussion Re: lift off hinges qld 2Feb 23, 2018 8:05 pm Hi Rayg, I'm assuming you've had some work done that required a permit? In short, the answer is yes they can. My QLD knowledge is limited, but if you needed a permit for works, then depending on the scope of works, size of job(vs original house size) any area deemed not compliant by the surveyor/inspector can have a defect. It happens a lot with QLDers especially where they are on stumps and need to be lifted to meet minimum access requirements. As much of a pain as it can be, be glad its only about $100 of work Re: lift off hinges qld 3Feb 24, 2018 8:47 am CF Design Hi Rayg, I'm assuming you've had some work done that required a permit? In short, the answer is yes they can. My QLD knowledge is limited, but if you needed a permit for works, then depending on the scope of works, size of job(vs original house size) any area deemed not compliant by the surveyor/inspector can have a defect. It happens a lot with QLDers especially where they are on stumps and need to be lifted to meet minimum access requirements. As much of a pain as it can be, be glad its only about $100 of work Hi CF Design Thanks for your advice and I should have been more specific. There has been no reno work or additions the house is as built in 1977 and we are the third owner and have it on the market for sale, we have done a council check on final inspection (which we did not have done when we purchased, lesson learned)(we have since found out this is quite common in QLD) and this was not done. We organised councils private certifier to do the final inspection as we did not want any issue with any real purchaser (LOL). I assume the hinge change on toilet doors started in or around mid 1990's in QLD. We are just trying to find out if the can make you renovate these changes that we instigated after the house was built(1977). This person even picked on some soncrete sleepers in the garden because they look like the could be used as stairs, they want them removed. Starting to look like we may have to go legal. Re: lift off hinges qld 4Feb 24, 2018 9:59 am From what you are saying, it sounds like you shouldn't have to do any work as they are measuring a current standard vs as built in X year. The only thing that will impact is if there were any permits issued for works that have since been done and that didn't meet the standard(I.E the surveyor missed or a permit was required but not sought/granted) I'm not familiar with the requirements/need/want of a council inspection for a sale as its not something that happens in VIC. The only thing that might relate to it here is a statement in your sale docs about knowledge of un-permitted works. One way to address any issues is to have the list of items ready for discussion with any buyer and negotiate based on the value of the works required. If the estimate to complete the works is $2k, tell the buyer how much you want and then take $2k off for the estimated works Re: lift off hinges qld 5Feb 25, 2018 1:38 pm CF Design From what you are saying, it sounds like you shouldn't have to do any work as they are measuring a current standard vs as built in X year. The only thing that will impact is if there were any permits issued for works that have since been done and that didn't meet the standard(I.E the surveyor missed or a permit was required but not sought/granted) I'm not familiar with the requirements/need/want of a council inspection for a sale as its not something that happens in VIC. The only thing that might relate to it here is a statement in your sale docs about knowledge of un-permitted works. One way to address any issues is to have the list of items ready for discussion with any buyer and negotiate based on the value of the works required. If the estimate to complete the works is $2k, tell the buyer how much you want and then take $2k off for the estimated works Thanks CF Design There have been no extra works and no other permits required since 1977. We will just have challenge (with a competent solicitor)through whoever the correct people are in QLD. We do know that all other inspections were done during the build just the final sign off which apparently was the done thing in QLD back in the old days, the assessor / certifier would drive past and see that the landscaping was done and people looked like the had moved in so when back at the office instead of following up the builder he just filed the whole build file away and now they want to pass on their incompetence to follow through onto the new purchasers. Yes, I had already tried searching those. In the end I am fabricating my own. 4 4173 Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4242 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5006 |
