Browse Forums General Discussion 1 Nov 15, 2017 4:44 pm I’m looking for a curtain track that will cover a set of 4.6m stacker doors. I want the curtains to all go to one side, rather than half to one side and half to the other. I also don’t want to make a feature of the curtain track. I know there a quite a few options available (e.g. Bunnings). I’d appreciate any reviews or comments people have on what they have used. Thanks Curtain track recommendations for using with stacker doors 2Nov 26, 2017 5:42 pm I don’t have stacker doors just sliding, but it’s a 4 metre long one and we used just the regular bar from Bunnings, however they don’t have them long enough (or at least didn’t then) so my OH joined two poles together and used 3 brackets to hold it up. Over time one side has bent slightly probably caused by naughty kids hanging off curtains, so it’s probably not the most sturdy option...but definitely the cheapest Re: Curtain track recommendations for using with stacker doo 3Nov 26, 2017 5:49 pm As for going all to one side, sheers would be fine but if your using heavy curtains you’ll need something strong to hold the weight. Also, if you want it all to one side you’ll probably need something professionally done as anything that long diy would probably need a middle support which might stop all curtains going one way (that’s the case with ours anyway). Hopefully someone else has a good suggestion for you What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12393 Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9481 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7911 |
