Browse Forums General Discussion Re: Under Tile Roof Insulation Without removing Tiles 2Nov 15, 2017 5:01 pm Try foillboard, its rigid easy to cut and fit and should not sag, you can buy 10 15 and 20mm and is polystyrene core with double sided aluminium foil Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28327 looks experimental to me, reinforced screed would be a better option or even better insulate between ground and structural slab. I would not put granite over that,… 3 4999 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 20936 |
