Browse Forums General Discussion 1 Nov 08, 2017 6:54 pm Total amateur to the process here. Have a property in mind which has peaked our interest and immediately we have thoughts of the possibilities at this place - but who would the recommended expert be to discuss what would be / would not be possible, as that information would affect our bid amount? Cheers! Re: Knowing what is possible with potential home exension 2Nov 09, 2017 9:19 am Property developers, Designer/planners, Builders, Real estate agents, etc, etc all dabble? Also there is plenty of metadata, apps & Spreadsheets online. once you have determined the amount you need to spend on the development to turn a profit then reverse engineer the total Co$T into build elements, get a sketch, quants and apply realistic data and build costs. You can also make extra money by doing some of the work yourself.... In the old days the rule of thumb was to look for properties that were well below replacement cost.. its a bit more sophisticated these days but the principles are the same goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8203 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 1766 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6633 |
