Browse Forums General Discussion Re: Stormwaters and Water Tanks - total $46,350 2Oct 31, 2017 6:07 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 5Oct 31, 2017 6:36 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 8Nov 01, 2017 7:41 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwaters and Water Tanks - total $46,350 13Nov 11, 2017 9:45 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwaters and Water Tanks - total $46,350 14Nov 11, 2017 9:52 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 17Nov 11, 2017 10:11 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwaters and Water Tanks - total $46,350 18Nov 11, 2017 11:06 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 19Nov 20, 2017 7:01 pm I feel your pain. In the Northern Beaches area, our stormwater is costing us 33k+ (not including the rainwater tanks). The council is forcing us to do above ground/surface detention. So we have to put around our land a 50-60+m waterproof, masonary retaining wall. We went from a 15k PA (for stormwater OSD) to 33k+, probably more, as we will probably have to rip down and existing retaining wall. Re: Stormwaters and Water Tanks - total $46,350 20Dec 02, 2017 9:45 am rdcool Home_17 rdcool Yes, for any buildings a 10,000L underground water tank is required. For existing dwellings, above tank can be used. Which council are you building in? How big for you site coverage? We received the notice from builder which said storm water consultant suggested us accommodate 12000L water tank. We are told by consultant that council requires OSD for all new dwellings and our site coverage exceeds 35%.The raintanks will be partially used for internal re-use and the balance for OSD. But our BASIX only requires at least 3000L water tank. So is it possible which we can reduce size for the water tank? T Thank you. I am with Willoughby council, they require a 10000L undergrond tank for new buildings. Apparently the most costly items are the absorption trench and concrete version of the tank. Do you have to have an absorption trench? Did they quote you a price yet? I am in a similar boat, and I have been quoted $33,000 for hydraulics set up. My tender had a PA for 17K and was advised that was on a higher side!! Its interesting how the actual tender quote came up lower compared to original provisional quote, and that was used a selling tact/example by CSR to demonstrate how builders surprise customers by always putting provisions at higher side and customers end up saving money. But since the date contract/tender was signed - everything has been opposite and costing more! Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7496 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17356 |
