Forum General Discussion Re: Cant get my WATER PUMP going, any advice appreciated. 5Oct 04, 2017 12:29 am 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au Re: Cant get my WATER PUMP going, any advice appreciated. 8Oct 04, 2017 10:55 am 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au Re: Cant get my WATER PUMP going, any advice appreciated. 11Oct 05, 2017 12:12 am 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au Re: Cant get my WATER PUMP going, any advice appreciated. 12Oct 05, 2017 9:23 pm So it turns out the pump was faulty or became clogged with channel debris. It was not sucking hard enough to even become primed. I have taken it in for repair and will probably need to add a filter in the line. Re: Cant get my WATER PUMP going, any advice appreciated. 13Oct 05, 2017 9:37 pm That is why I asked if you had fitted a meshed check valve (foot valve). I hope that the pump wasn't damaged. The next challenge will be how not to clog the foot valve. Good luck. 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au You need to work backwards from the required flow rate at the sprinkler(s). It is impossible to give an opinion without knowing your flow rate objective, elevations etc.… 1 312 ![]() Topaz had a nice small valve that operated with low pressure, they might still make it. 5 1157 ![]() Hi All, I've had a bit of a frustrating time getting my pool pump going over the last few months. One day I switched on the pool pump and it gave out a humming noise and… 0 1527 |
