Browse Forums General Discussion 1 Aug 26, 2008 5:52 pm i drove past our house and noticed that the garage wall has been fully plastered, straight over where the internal door should be.
There are two big dots of paint/somethingapproximately where the door would go. Is this normal, to laster over it? I'd have thought they'd use multiple sheets and plaster around the door space... Building in manor lakes 2008 Re: plastering over garage internal door 2Aug 26, 2008 5:56 pm Are you sure you didnt drive by our house They have done the same thing...I would say easy for lockup and security, one less door they have to worry about for a few months.
Mrs B Re: plastering over garage internal door 3Aug 29, 2008 4:48 pm They've done it to ours too! Now I feel better, not being the only one!
xMel http://marshallmansion.blogspot.com/ If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 6837 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6357 |
