Browse Forums General Discussion Re: Builder stuffed up - irreversible mistake - what can we 5Sep 27, 2017 9:56 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Builder stuffed up - irreversible mistake - what can we 10Oct 02, 2017 7:06 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Builder stuffed up - irreversible mistake - what can we 11Oct 02, 2017 9:41 am building-expert Yes it seems you are stuck with something you did not want, unfortunately, but it highlights that quality in building is not a game of chance and quality (getting the result that meets your reasonable expectations) does not happen by accident. Its hard work: planning, communicating, checking, re-checking, monitoring, verification and correcting. You have specified what you want, communicated to the builder and still got the wrong outcome, why? Because it is not enough. It seems no one has checked that the floor grinder has got the right instruction and no one has asked that a small sample area be ground and approved as a sample for the rest of the slab. Yes, the builder should have done all that but who checks the builder? If you have critical requirements such as concrete grinding and exposed finish then you must have quality assurance system in place to monitor verify and correct. I agree with you. What quality assurance you would you have suggested? We tried to find out the exact time the floors were going to be done so we could be there for it but our site supervisor did not return our calls or texts. We do not live locally to the build and obviously have our own jobs to go to. The sample you suggested was also something I believe should have happened instead of going gung-ho at the slab. So where do we stand now? Re: Builder stuffed up - irreversible mistake - what can we 12Oct 02, 2017 9:52 am You could have went to an Architect and paid 30% more Plus fees..but you didn't Where do you stand, out of pocket either way ,I suggest you negotiate Tile costs with your builder Sorry to be blunt...Tho I can't see him losing out Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Builder stuffed up - irreversible mistake - what can we 13Oct 02, 2017 9:57 am StructuralBIMGuy You could have went to an Architect and paid 30% more Plus fees..but you didn't Where do you stand, out of pocket either way ,I suggest you negotiate Tile costs with your builder Sorry to be blunt...Tho I can't see him losing out I don’t think this information is correct. If your builder lays the wrong tiles or lays them crooked, they’re responsible for ripping them up and relaying them. Same goes if they use the wrong brick or paint the house the wrong colour. Re: Builder stuffed up - irreversible mistake - what can we 14Oct 02, 2017 10:02 am Fighting it comes at a cost..I suggest you check that out..as I said either way you lose out You will need to determine the optimum/best cost solution. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Builder stuffed up - irreversible mistake - what can we 15Oct 02, 2017 10:06 am StructuralBIMGuy Fighting it comes at a cost..I suggest you check that out..as I said either way you lose out You will need to determine the optimum/best cost solution. Not necessarily. In nsw we have free government agencies to assist in this type of thing Re: Builder stuffed up - irreversible mistake - what can we 16Oct 02, 2017 10:12 am For all the others that may find themselves in potentially similar position, if you have something critical that requires special performance then it should be specified and spelt out in the special conditions of the contract together with designated damages/remedies if the performance or quality fails. That way builder would have been on unmistakeable notice as to what would happen in the case of a default. Special conditions could have stated that owner approves sample floor area in writing before rest of the slab is ground You say you went with a custom builder, fine but many custom builder are no better than large project builders. it seems you tried but builder ignored you, I find this all the time. As to where you stand now? Not a very good place to be. Even if you go legal (it will cost you heaps) you may not get award for demolition and replacement of slab on the basis of a cosmetic defect only but may get some compensation. Whether that will offset money spent, probably not, however I cannot give you legal advice just the benefit of my experience. Perhaps your building problems coud have been avoided if you had your own building consultant or an architect looking after you. On architectural building jobs it is the architect that specifies required performance and enforces quality, you are building without one, see my drift? As a builder whospent a lifetime on architectural projects I know not to mess with architects, if you get it wrong you will be ripping it up and doing it again at your own cost and without extension of time. Architecturally supervised contracts have greater control over builder's performance requirements than standard housing contracts. What state are you in? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Builder stuffed up - irreversible mistake - what can we 17Oct 02, 2017 10:14 am I'm so sorry to hear this has happened. I totally feel for you - we're about to build and hoping to have nil exposed mechanically polished concrete with a matte finish. We're pretty scared about the process - because as you've mentioned, we didn't select different coloured stones. If they don't pour the slab correctly, our nil exposure might show aggregate anyway and we have no idea what it will look like. Our builder hasn't done many concrete floors either. Our SS is currently looking for the right company to do the slab, so he seems to care. Hopefully he gets it right for us. I know it's not what you wanted, but could you live with the exposed look? Do you have pictures? What was your desired theme for the house? I don't have a solution, but just thinking about what if this happens to us..... I'd probably lean towards keeping the current flooring as opposed to tiles, because I agree - grout sucks and I would prefer seamless concrete flooring. But I would certainly ask for compensation in other ways - some extra upgrades. I really hope you're able to find a solution that you're happy with. <3 Re: Builder stuffed up - irreversible mistake - what can we 18Oct 02, 2017 10:20 am Lee31 StructuralBIMGuy Fighting it comes at a cost..I suggest you check that out..as I said either way you lose out You will need to determine the optimum/best cost solution. Not necessarily. In nsw we have free government agencies to assist in this type of thing Here in WA the, Building commission isn't free, the first step is mediation and that comes at a cost. I suspect it is the same elsewhere Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Builder stuffed up - irreversible mistake - what can we 19Oct 02, 2017 10:25 am If something is free it usually is not worth having and is a waste of time. That's my experience in Victoria. People come to me after they wasted their time. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Builder stuffed up - irreversible mistake - what can we 20Oct 02, 2017 10:46 am staceyrussell I'm so sorry to hear this has happened. I totally feel for you - we're about to build and hoping to have nil exposed mechanically polished concrete with a matte finish. We're pretty scared about the process - because as you've mentioned, we didn't select different coloured stones. If they don't pour the slab correctly, our nil exposure might show aggregate anyway and we have no idea what it will look like. Our builder hasn't done many concrete floors either. Our SS is currently looking for the right company to do the slab, so he seems to care. Hopefully he gets it right for us. I know it's not what you wanted, but could you live with the exposed look? Do you have pictures? What was your desired theme for the house? I don't have a solution, but just thinking about what if this happens to us..... I'd probably lean towards keeping the current flooring as opposed to tiles, because I agree - grout sucks and I would prefer seamless concrete flooring. But I would certainly ask for compensation in other ways - some extra upgrades. I really hope you're able to find a solution that you're happy with. <3 Thank you. All I can suggest to you is get there before the polishing starts and talk to the tradies themselves and show them pictures and just make sure you are all on the same page. I tried to do this myself but yeah, lack of communication failed us and I got there too late. We signed off on pictures etc as well Which they provided to us but I’m still in this boat. I was going for an organic/eco look and the floor now looks very industrial so I’m not sure what to do. Good luck, hope my experience has helped you. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 Unless there were unforeseeable issues with the site, I dont think you should have to pay for contractors errors or poor planning. I'd probably try and be reasonable and… 5 4504 |
