Browse Forums General Discussion Re: Standing water in stormwater drain. Normal? 3Sep 19, 2017 3:00 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Standing water in stormwater drain. Normal? 5Sep 19, 2017 3:39 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Standing water in stormwater drain. Normal? 7Sep 19, 2017 5:24 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Standing water in stormwater drain. Normal? 9Mar 07, 2018 12:06 pm bashworth Looks more like an Overflow Relief Gully (ORG) which would have a water seal to stop the smell from the sewer. Check this link for more: http://anewhouse.com.au/2013/08/overflow-relief-gulley/ If the shower directly opposite the ORG is rarely used, is is normal that when that shower is ran, that a sewer smell comes up because water seal has dropped as water not ran often to top it up? Just wondering as this is happening to us on a new build. Only in the shower rarely used. Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 6341 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 4880 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 3564 |
