Browse Forums Heating, Cooling & Insulation 1 Sep 12, 2017 12:15 pm Hi all Just curious if anyone upgraded from Ultra Air's classic air con system to the ESP plus system? If yes, any feedback on the system? We were completely sold on the upgrade but just want to make sure we made the right decision. We're hoping the energy efficiency will save us money in the long term. Re: Air conditioning - upgrade from classic to Ultra Air ESP 3Sep 12, 2017 7:24 pm The Actron ESP Plus System is definitely more energy efficient provided you have lots of zones as it allows you to run as little as 2 outlets at a time compared to 4-5 on the Classic System. Re: Air conditioning - upgrade from classic to Ultra Air ESP 5Sep 16, 2017 7:30 am I have upgraded to the ESP Plus System for my new house with 8 zones + the Wi-Fi Module. I also sell these units and I believe it is worth upgrading from the Classic to the ESP Plus as it will be worth it in the long run. Re: Air conditioning - upgrade from classic to Ultra Air ESP 6Sep 18, 2017 11:11 am Hi Waigo, so is a ESP Plus 19kw system sufficient for a 37sq double storey open plan home? I think they will provide 18 outlets. Any recommendations we should look out or ask for? Re: Air conditioning - upgrade from classic to Ultra Air ESP 7Oct 07, 2017 11:05 pm Waigo I have upgraded to the ESP Plus System for my new house with 8 zones + the Wi-Fi Module. I also sell these units and I believe it is worth upgrading from the Classic to the ESP Plus as it will be worth it in the long run. Hi, which is more reliable in the long term- Actron 19kw single phase or Actron 19kw single phase Platinum Plus?? Re: Air conditioning - upgrade from classic to Ultra Air ESP 8Oct 09, 2017 8:14 am Hi waigo, i know the system only needs single phase power, but we kinda want three phase. We are building a single storey home. Are you using single or three phase and if you have single, are you finding it ok? i.e. no short circuiting or anything? Re: Air conditioning - upgrade from classic to Ultra Air ESP 9Oct 10, 2017 9:30 pm lymd1101 Waigo I have upgraded to the ESP Plus System for my new house with 8 zones + the Wi-Fi Module. I also sell these units and I believe it is worth upgrading from the Classic to the ESP Plus as it will be worth it in the long run. Hi, which is more reliable in the long term- Actron 19kw single phase or Actron 19kw single phase Platinum Plus?? I believe both offer the same reliability but if I was choosing between the 2 I would go with the Platinum Plus as that is a newer model. Re: Air conditioning - upgrade from classic to Ultra Air ESP 10Oct 10, 2017 9:32 pm I am using 3 Phase but my house needs a 23kw unit so that size only comes in 3 Phase. 3 Phase power will give you more power to the house which is good if you require it. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8984 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5899 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
