Browse Forums General Discussion 1 Sep 05, 2017 7:44 pm builder leaves me a under sink drain as shown in attached photo. I am going to buy front load washing machine. I doubt there will be a problem if I connect drain hose of washing machine directly with under sink drain. I might need to buy a adapter or something. can anyone shed a light? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to connect drain hose of washing machine 2Sep 08, 2017 10:24 am I remember an old rule about looping the hose - ie not just straight to outlet. Maybe it off-sets the pressure ? By looping I mean first around the down pipe then up and onto the connection point. Probably more here better knowledge than me tho ... Re: How to connect drain hose of washing machine 3Sep 08, 2017 11:09 am Just drill out that connection on the right, push the hose on, and tighten a hose grip to make sure it doesn't come off. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to connect drain hose of washing machine 4Sep 19, 2017 12:30 pm Yikes! that is NOT a pipe to attach a washing machine to! It's a connection for a dishwasher. A washing machine drains a huge amount of water and requires a drain of at least 60mm with a long drop and a trap. Like in the picture. https://i.stack.imgur.com/WMuZm.png Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17527 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4614 Agreed. I just found out today the certifier has not given the final sign off. 2 4173 |
