Browse Forums General Discussion 1 Sep 05, 2017 12:00 pm I have a Titan Goldstar stud frame shed. I want to be able to hang a couple of ladders, bikes and tools from the wall. I’m wondering the best way to do this – I’ve had a bit of a search but I'm a bit surprised I can’t find anything definitive that helps me. Questions I have include: • I assume I need to add additional noggings to do this? Is it better to use steel noggings or should I just use timber? • If using steel studs can I screw hooks etc. directly into this or do I need to screw ply/mdf onto the steel steel studs and then put hooks into that? I’m a bit new/unclear with this so any pointers would be appreciated. Thanks Re: Hanging items from steel stud frame shed 2Sep 05, 2017 12:21 pm Why don't you ask the manufacturers they probably get asked this all the time Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8021 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4458 |
