Browse Forums General Discussion 1 Sep 02, 2017 12:12 pm Hi, We have bought a block of land which is downward sloping (1:6m fall) and we are trying to understand roofing options that will handle the SE QUEENSLAND deluge, but also if it leaks we prefer pitched roofs so you can keep an eye on roofs and leaks. I find a skillion roof doesn't really have this ability. The issue is with a two storey house on piers and height restrictions (7.5m) I don't really know what roof type is a fit and how the roof and house would fall with the block. Looking for ideas. Regards Re: Roofing design downward sloping block 2Sep 02, 2017 3:01 pm It has nothing to do with the roof but everything to do with the roof drainage compliance that determines the gutter's cross sectional areas and the number and size of the downpipes for the roof areas drained to each downpipe but be aware that QLD houses are often built to the inferior BCA regs rather than to the superior Deemed To Satisfy (DTS) AS 3500.3. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12392 i did click it, still couldnt make it out rofl. in any case, doesnt look like too extreme a slope, you may be in luck. Just shoot out some emails to volume builders in… 3 18562 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7515 |
