Browse Forums General Discussion 1 Aug 17, 2017 8:48 am Hey Everyone, I haven't posted in this Section of the Forums before. So I hope that this is the correct place to do it. A long story short. I live in Victoria in the Council Area of Maroondah. In my fully detached House towards the rear of the property. There is a neighbors garage which has been built on the property line. This is a brick structure which has been in place for some 35 years or more. Well before the time I moved in. There is also no wooden fence separating our properties next to the garage. Just the brick wall on the property line. As you move towards the front of the property there is an easement which is a communal drive way for the multiple residents on their side. There is a wooden fence past the brick garage that divides our two properties. I have about 1 or 1.5 meters clearance between my house and the fence line. Okay, now here is the deal. I have been informed the Neighbor wants to convert the Garage into a bedroom. Putting the new bedroom wall onto the same property line as the old garage. Are they allowed to do this? Re: Neighbours garage on property line, wants bedroom 3Aug 17, 2017 10:48 am How can that be? Can you help me understand how the Council makes up these rules? When I was doing a house extension many years ago. My house needed to be at least 1 meter away from the property fence. There was no if's or buts about it back then. Why is it that the garage which is being planned to be converted into a bedroom, now being allowed by the Council? I don't understand the reasoning behind this. Re: Neighbours garage on property line, wants bedroom 4Aug 18, 2017 12:45 pm Informed by ... Council ? Have you spoken to Council ? Re: Neighbours garage on property line, wants bedroom 5Aug 18, 2017 2:22 pm sparkle07 I don't understand the reasoning behind this. You have already been given the answer to this and other Qs on Whirlpool. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Neighbours garage on property line, wants bedroom 6Aug 18, 2017 4:00 pm Yes, I am not hiding the fact I have been reaching out to different community groups. I was under the impression this forum might be better frequented by building industry representatives. Re: Neighbours garage on property line, wants bedroom 7Aug 19, 2017 1:08 am Frankly speaking, all your questions are answered on other forum. You won't hear an answer that you prefer to hear. As other already mention, no matter your neighbour is on boundary or behind wooden fence with 1.5m setback, there won't be any significant difference in noise level from your living area. At the end of the day, you will be the one that needs to control the noise level. It just that your neighbour's garage was acting as a sound barrier before but that doesn't mean that you can go over your noise limit. I'm starting my build soon and with Maroondah council as well. As long as your neighbour is not taking down the garage and only converting internally and meets all NCC and regulation requirements, council will grant them the permit even if you object. Re: Neighbours garage on property line, wants bedroom 8Aug 19, 2017 9:24 am I endorse the reply (below) that you received from 'bazzle' on Whirlpool. "You need to talk to the Planning dept at Maroondah Council... Asking on here may not give the same answers from those who make the decisions. I have approached councils in the past and got helpful information." Council's policies can also change and affect well meaning forum 'advice', whatever advice you receive from a forum needs to be checked and in your situation, that authority is your local council. Not everyone giving 'advice' will be conversant with your council's regulations. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7067 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7084 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17148 |
