Do I use gap filler or caulk? I seem to be getting mixed advice.
I also have hairline cracks in corners where plasterboard walls meet. Gap filler or caulk in this instance?
Thanks for the advice.
The spacing of the studs looks pretty large especially for a load bearing wall.
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,…
