front storm door
Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new…
17/01/2024
1
If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a…
7/04/2024
2
Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished…
