Browse Forums General Discussion 1 Aug 09, 2017 5:59 pm Hi, I am building a new home with Simonds. They poured the slab yesterday and there was light rain yesterday. Today they have started putting the frame up and I don't think the concrete would have cured properly. The supervisor said it should be ok as they are not putting the roof on for a few days yet. it is too early for the builder to start the frame? thanks Re: slab poured yesterday and framing started next day 2Aug 09, 2017 6:23 pm It is common practice these day. The frame has little pressure impact. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: slab poured yesterday and framing started next day 3Aug 09, 2017 6:32 pm Textbook says no but I have done it many times myself without adverse effect. If you are just walking on it and assembling light frames it should be Ok but i would not put a pallet on it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: slab poured yesterday and framing started next day 5Aug 10, 2017 6:49 am mickzoey Not so.. you will need to check your wind loading category and plate-> Frame anchoring system I've seen dynabolts & Hilti explosive anchors cracking slab edges ..please check for concrete cracking around Impact anchors. No Fixings No loading Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 4 6817 STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5838 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10675 |
