Browse Forums General Discussion 1 Aug 07, 2017 12:35 pm I have some galvinised fence posts I need to paint. They previously had some fixings attached to them which I have removed,. There are a number of ~10mm diameter holes in various places on a number of the posts. leftover from these fixings. Should I fill these before painting, and if so any recommendations on what kind of filler to use? Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4120 Hello, I am looking to install a fence but I tried to dig the holes with a post digger I realised the sand is very runny. Very, very runny. It just slides off the sides… 0 11209 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7075 |
