Browse Forums General Discussion 1 Aug 06, 2017 2:35 pm Hi all, Want to close up a gap between two rooms that is 2210 in length, 1130 in height and 120 wide. Have structural timber which is 90mm plus sheets of plasterboard 10mm. After attaching these I'll be left with the new plasterboard 5mm recessed from current wall. Put me straight here but once I add the resin and screw the plasterboard on and then paper & cement around the edges will 5mm be noticeable or do I pack between the studwall and plaster? Cheers Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17246 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6899 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45774 |
