Browse Forums General Discussion 1 Aug 03, 2017 5:17 pm Hi There Can someone help me, i got Storm wtaer pit at m,y backyard which is 3mt deep to my land area and i have to cover it with timber sleepers so my kids dont fall into it, But council are saying I am not supposed to cover and leave it open. Can someone advice what I can do Re: Covering Storm Water Pit 2Aug 03, 2017 5:58 pm Cover it. What is the council going to do? I'd look at getting a steel grate or mesh rather than timber sleeper. By all means place timber sleepers/decking over the steel to make it more aesthetically pleasing. Re: Covering Storm Water Pit 3Aug 03, 2017 6:10 pm A photo might help The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Covering Storm Water Pit 4Aug 03, 2017 10:26 pm Also mosquito proof it. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10471 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7815 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6843 |
