Browse Forums General Discussion Re: Need urgent advice about clay soil holding water vs a le 5Jul 29, 2017 11:06 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need urgent advice about clay soil holding water vs a le 8Jul 30, 2017 1:10 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need urgent advice about clay soil holding water vs a le 10Jul 30, 2017 4:43 pm Yes. As soon as the pressure controller registered the cut in pressure setting, the pump would start and recharge the line. Water is not compressible unless you have a handy black hole nearby, it doesn't take much fluid loss to lower the pipe's static pressure to the pressure controller's cut in pressure setting. Having a pressure tank would disguise it but the pump would also run for longer. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16295 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3275 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20236 |
