Browse Forums General Discussion Re: Need urgent advice about clay soil holding water vs a le 2Jul 29, 2017 6:16 pm Did you say the trench for the water pipe was only dug two months ago? If so the trench could still be wet from the backfilled clay, especially if it was not compacted in layers when reinstated. Regards James Mason www.renovationjunkies.com.au Re: Need urgent advice about clay soil holding water vs a le 4Jul 29, 2017 8:00 pm Unfortunately we don't have a Meter we are on tank water Re: Need urgent advice about clay soil holding water vs a le 5Jul 29, 2017 11:06 pm The trench that the pipe is in will have uncompacted soil along its length and act as a conduit. This is why houses built on highly reactive soil are required by AS 2870 to have clay plugs in the service trenches to prevent water using those trenches as conduits and flowing under the house. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Need urgent advice about clay soil holding water vs a le 8Jul 30, 2017 1:10 pm ![]() Unfortunately we don't have a Meter we are on tank water If the line is connected to the pump feed, a leak would make the pump cycle. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Need urgent advice about clay soil holding water vs a le 9Jul 30, 2017 3:22 pm even a very small one? Re: Need urgent advice about clay soil holding water vs a le 10Jul 30, 2017 4:43 pm Yes. As soon as the pressure controller registered the cut in pressure setting, the pump would start and recharge the line. Water is not compressible unless you have a handy black hole nearby, it doesn't take much fluid loss to lower the pipe's static pressure to the pressure controller's cut in pressure setting. Having a pressure tank would disguise it but the pump would also run for longer. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 4232 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 4105 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 21353 |
