Browse Forums General Discussion I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9976 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18425 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10284 |
