Browse Forums General Discussion 1 Jul 19, 2017 4:09 pm We had custom furniture made by a cabinet maker and was meant to be raw MDF but instead it came with a laminate finish that normally has 2pac applied. See photo. It is satin finish and very smooth. We want the same finish for the raw and laminate sections. How do you recommend we tackle this project? We have a Wagner Flexio 585 we were planning on using. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Searching for the perfect block of land on the Gold Coast is mission impossible! Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4903 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18301 |
