Browse Forums General Discussion Re: Metal frame house 3Jul 14, 2017 11:14 am It is more difficult to do DIY like shelves etc. I have no cracking issues in 20 years. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Metal frame house 4Jul 15, 2017 8:17 am Had 2 steel frame houses, one we bought and the other we rented while we built. I will never get another steel frame house ever again. They are horrible. They are noisy (they pop and ping when going hot to cold and vice versa), they are cold and draughty (you can't insulate them as well because the top plates and studs all have holes through them, also the batts can't get into the channels of the steel), if you get mice or rats in your roof then they use the C channels in the steel like highways, they are terrible to do any work in the roof space, hanging pictures or anything on walls becomes tedious because you need steel screws to go into studs, makes it very difficult to renovate in the future, in 5 years in our first house we got excessive plaster cracking in our room corners and above doors. Yeah never again for me I'm afraid I'll stick with timber. Re: Metal frame house 5Jul 17, 2017 12:10 pm Thanks for the heads up. Will talk to our builder if they can change it. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8084 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5535 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8640 |
