Browse Forums General Discussion 1 Aug 23, 2008 6:09 pm There're some quite wide windows/patio doors in my project, tall too. So tall in fact that there's not enough room left for the wide enough LVL lintels to span them. I've heard of the slim metal lintels that can be used with the timber frame to increase the span size. Anyone knows anything about them ??
Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Metal Lintels, timber frame ?! 2Aug 23, 2008 9:14 pm What height do you have to play with??
You may have to use a steel beam.$$$$$ Re: Metal Lintels, timber frame ?! 3Aug 23, 2008 9:45 pm Quote: What height do you have to play with?? You may have to use a steel beam.$$$$$ Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Metal Lintels, timber frame ?! 4Aug 25, 2008 3:48 pm The product you're after is called a bressumer "Z Beam". Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Metal Lintels, timber frame ?! 5Aug 25, 2008 8:15 pm You may need to have it engineer certified too Re: Metal Lintels, timber frame ?! 6Aug 26, 2008 7:31 am There are tables for Z beams, but if you need to incorporate with a timber lintel to carry the load then as Luke said it will need to be comp'ed.
The draw back with Z beams is that they need to be used in a brick veneer situation as the stiffener protrudes from the wall frame. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Metal Lintels, timber frame ?! 7Aug 26, 2008 10:53 am Thanks folks!
Found the Z beam tables, etc, and also another product called Light Steel Beams, on the net, but it's all a tad over my head. Quote: You may need to have it engineer certified too Dead right and I'll be consulting one shortly. Another hole in my budget, sighhhhh...... Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying This is 100% true. You can not hang anything on steel frames. very frustrating 8 7989 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5485 Thanks Pulse, thats really helpful and very much appreciated. Also thanks for the pointer on sheathing, thats me watching too many american youtube videos! 6 2788 |
