Double brick + brick veneer combo
Sustainability experts are recommending to reduce thermal mass for the first floor while concentrating it at the ground floor.
I am thinking of a hybrid construction - double bricks for the ground floor and heavily insulated brick veneer for the first floor.
What are the pros/cons and implications for this kind of approach from the complexity of building?
I suppose it should not be a big issue of adding a timber frame to the top floor and placing some bricks around it?
Thanks
Thermal mass of double brick without insulation can work against you if you get continuous hot sunny days.
Of course both will be heavily insulated.
WBR,
Alex
So unless you really want brick veneer on the outside and inside, for superior insulation you may wish to consider Insulating Concrete Form.
The other option is to use BV and plaster inside but with 140mm wall studs which will allow you to use R4.0 batts. You can use polished concrete floors for thermal mass.
5
depends on your council, some 1 day some 14 days
24/07/2023
Hey all, Hoping for some inspiration for my bathroom laundry combo. The tiles are in good condition, as is the bathtub. I’ve given it a coat of white paint and added…
