i am planning on attaching it to a bedroom structure that i have made so i will only need the slippery dip/slide bit.
What material do you recommend that will slide the best?
Thanks in advance.
Browse Forums General Discussion 1 Jun 19, 2017 9:27 pm i am planning on attaching it to a bedroom structure that i have made so i will only need the slippery dip/slide bit. What material do you recommend that will slide the best? Thanks in advance. Re: what would be the best & cheapest material to build a in 2Jun 19, 2017 9:32 pm *** SORRY *** ABOVE POST WAS MEANT TO SAY : "build an indoor slide" ON THE END OF THE ABOVE TOPIC SENTENCE. Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10571 0 4690 |
