Browse Forums General Discussion 1 May 29, 2017 3:28 pm Hi all Needing some clarification on the pipes which run across the property and whether this would be an issue in the future if looking to build or extend on the vacant land. The site is 1100m2 and has a house built at the very front 5 years ago. The contract shows the pipes running from the left side of the property along the length of the house and then crossing over to the right, therefore cutting across the middle of the land. I contacted Sydney Water about building regulations and they referred me to their technical regulations document re. concrete encasing and building a certain distance away from the pipe based on depth and diameter. I'm wondering if all of this means that the value of the property will be substantially impacted due to presence of these pipes. Would it be difficult to get planning approval for a secondary build like a pool and/or granny flat at the back. Many thanks for your input https://ibb.co/cE2ADF[url= https://ibb.co/ifQVDF][/url] [url= https://ibb.co/ifQVDF]https://ibb.co/ifQVDF[/url] Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10815 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 4 5116 |
