Browse Forums General Discussion 1 May 25, 2017 3:08 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi there, just looking for some advice, we had our front porch concreted and to me is looks way to sloped? I am assuming it needs to be a little sloped for water to run? but this just looks crazy uneven? any advice would be appreciated thank you! Re: Front porch slope.. is this normal standards? 2May 28, 2017 11:13 am Have you measured the gradient of the slope? A certain degree of slope will be required for water runoff but based on the pictures it does look quite noticeable. It also looks like a bit like the slope is not evenly dispersed. It is definitely worth raising the issue with your builder before tiling as it will be easier to rectify and level now if necessary. Re: Front porch slope.. is this normal standards? 3May 29, 2017 6:13 pm Agree with pickylady completely. Talk to the builder before tiling. Re: Front porch slope.. is this normal standards? 4May 30, 2017 11:26 pm Thanks for your replies! we haven't measured yet as unsure what measurement to take? and yes it all looks like it falls to the front right hand corner def not evenly to the from if that is what it is meant to do? A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 180419 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 18978 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 890 |
