Browse Forums General Discussion Re: Relocate Home 2Apr 13, 2017 8:34 pm Id say about 20K. The problem is, the costs of moving is only the start. Your council will treat it as a new build, and expect your compliance to all current building standards - electrical, plumbing, Energy efficiency. You'll need a building application, and it will go through the normal inspection process. All of that could be another 30K minimum easy. They will ask you to bring the outside appearance up to scratch also - new roof, re painting, etc if those things are shabby in any way. Speak with your council. Re: Relocate Home 3May 22, 2017 12:17 am A 3 bed house is a pretty big home to move, but I'm pretty sure it can be done. Best you find someone who has had experience doing it and get quotes from them to get a better gauge. They'll probably be able to fill you in on all the other things that can be expected when you move the entire building so you can be prepared for what may or may not happen and the repairs that you'll have to undertake in order to get the house back to liveable state again once its moved... What seems to be the officer's problem? Our relationship with the owner is good, but I'm not sure if I want to impose putting a pole on their property. Your conversation with your neighbour must have gone well… 4 9861 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 17038 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 111226 |
