Browse Forums General Discussion 1 Apr 29, 2017 7:28 pm I have a speaker to install and the join between 2 plaster sheets is exactly where I need my in ceiling speaker to go. Can i cut the hole over the 2 plaster boards where the join is or is this risky for cracking? can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4533 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 19201 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5148 |
