Browse Forums General Discussion 1 Apr 28, 2017 9:28 pm Hi, I just found out from someone that my current builder is using Boral Total Joint Finish on the outside on the blueboard & supposedly you can't? And used Cornice cement on the ground to cover a gap roughly 3 inches wide outside because he said it sets like concrete and can use it? I assume he's not being honest & I will need to get someone in the rip off all the total join finish he has put on? Evening, Had my 3 month maintance done on my new place. Most things are fixed to ok standards, but im not sure about the visible joins in my plaster wall. There was 2… 0 4605 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 7409 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 9082 |
