Browse Forums General Discussion 1 Mar 08, 2017 6:04 pm Hi,
I am in Melbourne. Can anyone share any recommendations on companies they/builders use to professionally - repair dents in new aluminium stacker/sliding door panels - touch up 2pak - touch up scratches on aluminium frames of Windows/sliding doors - touch up scratches and small dents in engineered flooring - French oak Thank you Re: New build - Repairs - touch ups - builder tips 2Mar 09, 2017 6:39 pm Look on Melbourne bath repairs website. New build - Repairs - touch ups - builder tips 5Mar 09, 2017 9:25 pm TBLMan Can't get the builder to fix it, seeing as they damaged it? Hi TBL man. that was what I expected and hoped. Gets to the point that I would like some control over repairs and quality of repairs Any more names of repair- touch up companies like the ones that builders use when damage is found would be much appreciated. Thanks I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10031 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3066 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4882 |
