Browse Forums General Discussion Re: Breaks in Drainage Pipe 2Mar 03, 2017 10:21 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Breaks in Drainage Pipe 4Apr 19, 2017 7:48 am The fact that they went out to look for it means that they will get a contractor (usually very experienced as they do it everyday) and seal the cracks from the inside. This is a huge cost to them of which they will strive to do it right the first time. It costs the builder $100 per hour to inspect and $2,400 or so to seal, plus material. 1. Is it normal? Normal, No - Common, Yes 2. should I be concerned with it? if yes, should I get another independent company to check the breaks are fixed? The fact that they have spotted it, you should have 95% less of a concern. It took our builder 6 years to find our cracked pipes. Over the years, water will get to the soil below your foundation and cause all issues. Until they did the checks, we had no idea that there were cracked pipes. So the fact they spotted em, you are in a better position. 3. what kind of company should I call if I want to reassure myself and how much would it cost? You can get a plumber that specializes in pipe inspection and repair.... at $100 per hour (that's builders rate) and it takes half to a day to check your whole house One think I would insist and this is something the supervisor would be fully aware of is if the roof trusses are "free" from the walls. What this means is that when the chippy nails in the movement plate, it allows the trusses to move up and down freely to the walls. If they nail it in too hard or don't let enough "play" in the plate, it could pull up your walls. Re: Breaks in Drainage Pipe 7Apr 27, 2017 3:35 pm Joker What type of building practices and personal have we got when doing the right thing is considered, like winning the lottery(blessed). Plenty of examples to the contrary on this and other forums unfortunately. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Breaks in Drainage Pipe 8Apr 28, 2017 12:32 am yhfg27 I was told by site supervisor they found a few small breaks in the drainage pipe by using camera detection. Site supervisor said they would fix the breaks. , How have you gone? Adam.M You can get a plumber that specializes in pipe inspection and repair.... at $100 per hour (that's builders rate) and it takes half to a day to check your whole house . This is helpful information for others of us lurking too. Thank you Adam. We had a plumber complete an inspection of our large home in under an hour. Couldn't get the camera into a few of the areas we wanted the pipes inspected due to specific concerns of possible damage during build. We weren't reassured. Feel even less reassured now that you've indicated that it typically inspection of whole house takes 1/2 day minimum. I am to have the pipes reinspected after they are cleaned. Will look at a company that specialises in this as per your and Insider's suggestion. Can they use camera to look at pipes under the slab too? Re: Breaks in Drainage Pipe 9Apr 28, 2017 7:15 am If your drainage pipes are broken then that is potentially a serious issue and a risk to foundation material. In my view, broken pipes must be replaced and drains tested on completion. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Breaks in Drainage Pipe 10Apr 28, 2017 8:05 am The forensic plumbers generally do two types of test the first one which takes about 1-2 hours is a camera inspection of the stormwater thats if things go relatively smoothly.The other main type of test is the sewer which is a flood tested which takes longer to do and requires the plumber to find the inspection pit in the backyard.It can take several hours to do correctly. You can also flood test individual sections of the stormwater pipes. If the leaks are not large then the plumbers can reline the pipes instead of digging up replacing them but it will require a plumbers expert judgement . I have seen some plumbers find leaks in stormwater pipes after a previous plumbing inspection had given the pipes the all clear so good equipment,experience and professionalism count for everything. Re: Breaks in Drainage Pipe 11Apr 29, 2017 4:07 am insider The forensic plumbers generally do two types of tests. I have seen some plumbers find leaks in stormwater pipes after a previous plumbing inspection had given the pipes the all clear so good equipment,experience and professionalism count for everything. Thank you for the clear explanation of the different tests. Very useful for planned re:CCTV. Knowing what is and is not being done. And this time I'll be using a company that specialises in this. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7320 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4859 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3232 |
