Browse Forums General Discussion Re: Stormwater pit in new estate 2Feb 18, 2017 8:10 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Stormwater pit in new estate 4Feb 19, 2017 9:51 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwater pit in new estate 5Feb 19, 2017 9:56 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater pit in new estate 6Feb 19, 2017 10:10 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwater pit in new estate 7Feb 20, 2017 11:04 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater pit in new estate 10Feb 24, 2017 8:39 pm It's an open stormwater drain. Kinda sucks but that's where everyone else's runoff will go. Just be careful about trying to build anything around or near it as the effect could direct water where you don't want it to go, including into your neighbours. Hide it with some bushes (but not gardens as they'll be washed away). Maybe some low growth grevillea. They're pretty hardy. Hi All! I have engaged a plumber to re-do the stormwater drainage system on my property which is mid-70s and had blocked/cracked clay pipe drains. The works has… 0 18713 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10474 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 |
