Browse Forums General Discussion 1 Feb 14, 2017 3:53 pm It'still no where near finished!!! Back view is much nicer....but I will wait until it's closer to being finished to take a photo and show you all. This is NOT the colour - It's only the under coat of the acrylic render....the actual colour is finished on top of the garage if you can see it in the photo. It's called Dulux Colorbond Dune. Can't wait for the rest of the house to be rendered to get rid of those orange bricks and that cement look!!! I'm just wondering if I could get your opinion on what colour to do the aluminium slats that will be going across the fence? Some say I should go dark like the roof (Monument) but I'm thinking to match it to the windows and do the colour 'Surfmist' which is like a white colour (light grey, looks white) Same as garage? What colour?? and should I do an Alucobond garage door? Thanks all Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: So far...my new house :) FRONT VIEW - A bit of advice ne 2Feb 14, 2017 4:17 pm I am far from an expert on such matters - but the roof match might be nice. Although an off-set (lighter) colour might be good too). Re: So far...my new house :) FRONT VIEW - A bit of advice ne 3Feb 14, 2017 4:24 pm Thanks I actually think I will go with the lighter colour slats Re: So far...my new house :) FRONT VIEW - A bit of advice ne 5May 25, 2017 1:11 pm I think the lighter aluminium will age better, I find that the darker colours fade over time. I think matching to the windows will look good and should only need a light hose down every now and again to keep looking fresh. Re: So far...my new house :) FRONT VIEW - A bit of advice ne 6May 27, 2017 8:41 am Maybe also - check out what's around you. The colours being used. I like lighter. House looking good. Hi, we live in an area where the black soil is prone to a lot of movement. We have an old 50's house with masonite everywhere and nails popping out, warping, rusted etc.… 0 4510 The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 5678 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
