Browse Forums General Discussion 1 Feb 08, 2017 12:20 pm Is there a way to tell if there is flashing in the valley of the roof and if there is what sort of material it may be? Can you tell if the flashing is made of lead by sight? Pics linked. Thanks! https://imageshack.com/i/pnSHl9sMj Re: Roof flashing material by sight 2Feb 09, 2017 9:12 pm Can't tell anything from that photo but most flashings are lead free now. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Roof flashing material by sight 3Feb 09, 2017 9:58 pm To me that looks like a standard valley gutter made from zincalume steel Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10759 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8705 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6305 |
