I have a pine lined house, if not too costly I was considering changing some of the internal walls with a brick exterior to a painted brick interior. Any advice would be great thanks.
Katrina
Browse Forums General Discussion Re: Can I change a brick veneer wall to double brick? 2Feb 08, 2017 6:40 pm new_kat I have a pine lined house, if not too costly I was considering changing some of the internal walls with a brick exterior to a painted brick interior. Any advice would be great thanks. Katrina Anything is possible, but that would cost an absolute bomb, not worth considering. Most tradesmen would probably tell you it can't be done as well. Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au 5 10477 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4463 2 8359 |
