Browse Forums General Discussion 1 Jan 29, 2017 9:48 am Hi guys, I hope someone could help me out. I've put stepping stone and rocks around the house. Just realised I'm short on ground clearance to weepholes. Any ideas as to how I could go about this without breaking my back. I had no help and did the whole house by my self and don't want to pull up all the rocks and stepping stones! I'm thinking of digging holes next to each brick that has a weephole and either put something decorating or plant something. Any advise would help! Much appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Ground clearance - weep holes 2Jan 29, 2017 12:56 pm At least 1 brick height. The doco linked explains it with pics http://www.residentialreports.com.au/wp ... mpness.pdf Re: Ground clearance - weep holes 3Jan 29, 2017 1:11 pm Berek At least 1 brick height. The doco linked explains it with pics http://www.residentialreports.com.au/wp ... mpness.pdf Thanks mate. Looks like I have to dig this up now! it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7084 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5436 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11170 |
