Browse Forums General Discussion 1 Jan 21, 2017 5:11 pm Does anyone know the depth builders use to run stormwater under ground to the legal point of discharge? As well as the depth to connect power to the slab from the streeth? Re: Depth of stormwater pvc and electrical underground? 2Jan 21, 2017 6:40 pm chrismarshall3 Does anyone know the depth builders use to run stormwater under ground to the legal point of discharge? A registered and licensed plumber must lay stormwater pipe but I have answered queries where a builder or some lackey has done it. For a single dwelling, if the stormwater pipe is not subject to vehicular loading and there is no paving, the pipe must be buried a minimum (from the finished surface at the top of the pipe) to a depth of 100 mm. If the area is to be paved with brick or un-reinforced concrete, the pipe must be buried from the top of the pipe a minimum of 50 mm below the underside of the pavement. For other than a single dwelling, it is 300 mm. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Depth of stormwater pvc and electrical underground? 3Jan 22, 2017 10:11 am Do builders usually hand over acurate plans of where these pipes will run? Dont want to dig it up. Re: Depth of stormwater pvc and electrical underground? 5Apr 17, 2017 5:12 pm Electrical: Minimum 500mm depth of cover Or 300mm below concrete of the concrete is >75mm thick (excludes pavers, bitumen etc) measured from under the concrete (e.g 300mm + 75mm) Telecommunications: minimum 300mm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 853 |
