Browse Forums General Discussion 1 Jan 17, 2017 1:03 pm We are renovating our small workers cottage in Moorooka after 15 years of living there. This block is flanked by two unit blocks both had soil Class M reactivity however, our report has returned a SITE class P. The house is 50 years old post war stump workers cottage, no cracking or floor subsidence inside, no evidence of cracking of plaster work in our last 15 years of ownership. Could the soil report have made an error in its classification? Bore hole #2 @ 0.5m –0.8m:-l.s.s. = 1.4% Ys = 20mm Ys calculation for zone of influence of trees:-Yst = 30mm Cheers for any assistance Re: Soil Testting 2Jan 17, 2017 8:12 pm effectsize63 We are renovating our small workers cottage..... Why did you need a soil test? Is it a reno, extention or kdr? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Soil Testting 3Jan 17, 2017 8:40 pm As indicated previously, the Site Classification must consider many aspects of the site, not just the reactivity of the soil. P sites are those that include other factors that need to be brought to the attention of the owner, builder and footing designer. A “P” classification does not indicate a specific Ys value and is described as a “Problem” site. The reasons for a P classification include: Growth &/or Removal of Trees will cause Abnormal moisture conditions in the subsurface soils; Unusually high moisture conditions caused by water flow, ponds, dams etc; Sites with Loose fill which can be either “controlled” or “uncontrolled”. The P Classification depends upon the depth and type of fill; Sites with poor bearing capacity, soft soils, or soils which are prone to collapse; Sites prone to mine subsidence, land slip, piping or coastal erosion; Sites which for one reason or another cannot be classified as normal sites; Re: Soil Testting 5Feb 15, 2017 8:14 am A lot of engineers are now (wisely) recommending soil moisture tests and monitored daily watering for 2 weeks to rehydrate the soils of KDRs to acceptable moisture levels prior to construction. KDR sites are known for being very dry and having a different footprint with extreme moisture differences after construction is not good. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13098 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37143 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5194 |
