Browse Forums General Discussion Re: Soil Testting 2Jan 17, 2017 8:12 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Soil Testting 5Feb 15, 2017 8:14 am A lot of engineers are now (wisely) recommending soil moisture tests and monitored daily watering for 2 weeks to rehydrate the soils of KDRs to acceptable moisture levels prior to construction. KDR sites are known for being very dry and having a different footprint with extreme moisture differences after construction is not good. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13098 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5193 |
