Browse Forums General Discussion 1 Dec 04, 2016 12:06 am Am building a skillion roofed pine timber frame and hardie clad house on stumps in Augusta WA ...was wanting to know if the blue primed pine barge and fascia boards ( H3 treated and painted in light blue colour and made in Chile)which will hold the colour bond gutters and metal fascias should be reprimed and painted before the gutters and metal facsias are installed. The roofer has started to install the gutters ....will the wood rot under the gutters etc without this extra paint protection?The remaining visible section of the boards will obviously be painted by our painters. Cheers and thanks for your help...Stovey DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6575 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52849 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10940 |
