Browse Forums General Discussion Re: Any changes do think 2Dec 01, 2016 3:33 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Any changes do think 4Dec 02, 2016 6:38 am Building the Denver by Metricon on acreage Land settlement: 24/8/15 Contracts: 8/7/16 Finance approved: 5/8/16 Council approval.....? viewtopic.php?f=31&t=79213 Re: Any changes do think 14Dec 24, 2016 10:44 am algernon It brings the kitchen and associated living space to the north, where you can take better use of the passive solar gain - making your house much warmer and more comfortable in winter. Having the bedroom to the south puts it on the cooler shaded side of the house - making it cooler and more comfortable in summer, Doing that swap would also mean that you could better align the traffic flows from the front door and the garage into the living areas - as it stands now, you have to traipse the full length of the house to get to the living areas from your entries. Quite a bit of a journey when you're carrying shopping, and any guests are automatically taken on a full tour of the house - including any messy areas on the way! If the kitchen was where the master is now, then it's only a short passageway from both the garage entry and the foyer to get directly to the living areas - and a screening wall to the south of the new kitchen (where you currently have that triangular area with the couches) will then keep the 'bedroom wing' private from both the entries and the living areas (this would also make for less noise getting through to the bedrooms than in your current plan). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What about this one Re: Any changes do think 15Dec 24, 2016 10:57 am Much, much better IMO. Full utilisation of the space available. Living area flows well into the alfresco. Strategically places storage cupboards overcome the odd angles. The study is quite large. Virtually an extra bedroom. You might consider shifting the wall about 200-300mm in to make the master bedroom a little larger. All depends on how you would use that room. You may already have this on the drawing (a bit hard to tell). On opening between the 2 corridors you could put in a double cavity sliding door (2 x 820). That way you can open it up or close it off as needed. Overall I think this is a great design. Re: Any changes do think 18Jan 27, 2017 9:57 am The second one looks much better, better use of space and not the huge hallways at the front. Agree it would be good to minimise the study and make the master bigger Our Trinity Lux Q1 with Plantation Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=85254&view=undread#unread Insta: @newhomedream No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6587 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5733 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12647 |
