Browse Forums General Discussion 1 Nov 22, 2016 7:01 pm Hi, I live in Sydney and I'm looking at properties in Hobart, Tasmania in the $500-600k range. Many of the new properties are rendered cement sheet construction with single-pitch colorbond roofs. They appear to be good quality, judging by the standard of the fixtures and fittings, but I'm not familiar with this construction. Is this a durable construction method ? I presume there must be some form of frame; is this likely to be steel ? I'm concerned about energy efficiency, so what questions do I need to ask about insulation ? Are there any online resources I can look at to educate myself a bit more ? Lastly, a question for any Hobart residents; is double glazing an important consideration ? Thanks for any guidance you can provide. Tony Button. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4496 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3161 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18101 |
