Browse Forums General Discussion 1 Nov 14, 2016 5:08 pm Hi all I'm new to the forum.After doing some searching about the problem I have encountered.I found this forum.The question I have building a new home and we are at frame stage.After doing some inspecting of the home I found cuts in the frame in a few places with wedges placed in the cuts & spray paint colored timber.I have no idea what it is or why could someone enlighten me please.It probably something simple but its just not registering at the moment.Thank you so much in advance. Re: Wedges in new frame. 2Nov 14, 2016 5:32 pm george52 Hi all I'm new to the forum.After doing some searching about the problem I have encountered.I found this forum.The question I have building a new home and we are at frame stage.After doing some inspecting of the home I found cuts in the frame in a few places with wedges placed in the cuts & spray paint colored timber.I have no idea what it is or why could someone enlighten me please.It probably something simple but its just not registering at the moment.Thank you so much in advance. You have not posted a photo but it looks like they were straightening frame. If a stud has a significant bow you can partly cut it to straighten it but I always nail another long piece on the side to reinforce where cut is. I once had a carpenter who did what you described and I nearly fired him and I would have if he did it again. In my view cutting and wedging is not acceptable and I would not have it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Wedges in new frame. 4Nov 15, 2016 10:12 am 1) Upload your photos to an image hosting site like Photobucket. 2) Click on your photo in your Photobucket library or "recent uploads " that you want to post here. 3) Locate the IMG tag under "Share Links" on the right hand side of the photo. 4) Click on that IMG code line which will copy it ( the line will turn yellow and say " copied " ). 5) Paste that into your post here then hit the submit button. If you have a smart phone then using Tapatalk etc for a direct upload here is probably easier... Re: Wedges in new frame. 9Nov 16, 2016 6:52 pm I've seen guys poncing about doing a cut, nailing cleats on the side etc etc but it is only marginally faster than ripping out the bent or crook stud and just replacing it. Stewie Re: Wedges in new frame. 10Nov 16, 2016 7:39 pm Thank guys for your input.I had no idea what I was looking at.Also try get a viewing of my new house with the home builder supervisor is like finding hens teeth.Everything is a battle with them.thank you George. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8030 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28320 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4458 |
