Browse Forums General Discussion 1 Nov 02, 2016 6:58 pm I have an old hall that I am renovating. The biggest problem is that it is so cold. I have filled cracks and hole, insulated walls and ceiling but the cold comes up through the floor. The floor has a lovely old hardwood floor. There is no access under the house so I can't install under floor insulation. Does anyone have any suggestions on how I can keep the floorboards but make it warmer please. I don't really want to carpet over the timber. Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12666 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2607 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 |
